It is currently Thu Aug 07, 2025 6:15 pm
PostPosted: Wed Mar 07, 2018 6:27 pm
First name: Rob
Last Name: Lak
State: Massachusetts
Hi all... been absent for a while but plan to get more active.
I just bought the contents of a small hobby shop geared for guitars and have been doing an inventory - Yeah, i know, backwards - but i think i did OK.
So there's a few things that i have no idea what they might be, so i thought i'd post them here to see if anyone could ID.
This is the first... is it even related to to a guitar?
that black lever under that rubber "foot" forces that rubber foot in and out like it clamps to something.
The black lever at the base of the silver rod allows for adjustment of the rod.
Any ideas?
Thanks in advance!
Rob
PostPosted: Wed Mar 07, 2018 6:47 pm
First name: Rob
Last Name: Lak
and here's mystery tool #2
Some type of clamp... maybe for saddle and nut carving?
PostPosted: Wed Mar 07, 2018 6:59 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Whits looks like a binding trimmer/thickness trimmer maybe?
PostPosted: Wed Mar 07, 2018 7:04 pm
Yes the second one is for binding and is quite handy. THe first is just some sort of hold down.
PostPosted: Wed Mar 07, 2018 7:10 pm
Last Name: Sollod
The second one I think is to attach plastic purfing to plastic binding with acetone...
www.swiftcreekguitars.com
PostPosted: Wed Mar 07, 2018 7:16 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
The top looks like a clamp that you would use by drilling a hole the size of the threaded bolt into you work bench, insert with a washer on top of the bench and underneath the bench, tighten the eye on the bolt and then it clamps downward to your bench instead of needing an oversized super deep clamp to accomplish the same thing. Useful for all kinds of things I would imagine.
PostPosted: Wed Mar 07, 2018 7:27 pm
First name: Rob
Last Name: Lak
Fingerstyle.... that sounds likely! The loop on the end had me scratching my head, but maybe he lost the nut. Gonna search on that... Thnx!
Found it on Amazon... https://www.amazon.com/Quick-Drill-Pres ... B0033AYY2O
PostPosted: Wed Mar 07, 2018 9:16 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
That first one does what Joey said, but I’m pretty sure it is designed for a drill press table as a work hold down.
PostPosted: Wed Mar 07, 2018 9:22 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Yup. Cam clamp for a drill press. You can use it like a bench dog clamp, as well.
Alex
PostPosted: Thu Mar 08, 2018 4:27 pm
Last Name: Sollod
Binding Laminator...
http://www.stewmac.com/Luthier_Tools/To ... nator.html
Users browsing this forum: No registered users and 40 guests
